RUT200 7.14.2 upgrade issues
After upgrading RUT200 to 7.14.2 from 7.13.4 firmware keeping settings, encounter a serie of issues, router became offline. After local reboot, still internet access blocking, queue packages not able to download.
Solution was downgrade to previous firmware and restore from saved settings.
Good afternoon,
Thank you for the provided advice, I am sure it will be beneficial.
Just to clarify, are you looking to troubleshoot the device?
Alternatively, as the issues you mentioned are quite abstract, I would recommend to wait for the next firmware update, as it will likely fix them. If the issues persist, we can look into the further.
Please advise on your preffered path forward.
Arturas
Just to clarify, do the issues persist after installing the new firmware upgrade? Or is the device operational?
Arturas
Hi, thank you for your concern,
Since the refereed upgrade brought some inconvenient issues on a production router, I would prefer to test it in a second unit in bench environment before upgrade production units.
As soon as possible I will post feedback.
Best regards
