RUT200/241 with Automatic Gates
hello,
did anyone try to connect RUT200/241 devices to Automatic gates? if so, how and what was the proccess?
also, i try the guide in the WIKITELTONIKA but it is only with SMS and it didnt worked for me.
also, is their any good app to use so i can open the gate remotly? like home assist?
Could you please clarify what you mean by “automatic gates”? Are you referring to an SMS gateway? If so, have you tried following this RUT200 Mobile Utilities - Teltonika Networks Wiki guide? If not, please provide more information about what you are trying to achieve, and if possible, include a link to the guide you used for the configuration.
hey,
we want to operate entry gates with dry contact.
the method will be SMS or an APP that will send a command to the router with RMS API.
i want the residents to be able to open the gate by calling, SMS, or push in an APP.
Thank you for the clarification.
For your setup, the router’s I/O port should be connected to a relay that controls the gate. You can configure the I/O settings in Services → Input/Output via the WebUI.
Digital Input: Reads the voltage level of the relay to determine if it is on/off.
Digital Output: Used to power the relay and control its on/off state.
To trigger actions, you can change the I/O state using SMS messages, which can be configured in Services → Mobile Utilities → SMS Utilities under SMS Rules. Alternatively, you can use calls, which can be configured in Services → Mobile Utilities → Call Utilities.
Additionally, here are some useful wiki pages that should help with your setup:
