I am trying to connect a RUT145 to a Kamstrup omnia e-meter CT via the Han connector.
I am not sure if the wires are connected correctly, I get this error
“error”: 260,
“result”: “Failed to make connection with device: Not enough memory available.”
How can I check if the wires are connected correctly?
hi, could you maybe send pictures of how you have it wired and the pin diagram of the han connector?
screenshots of the serial configuration you have on the rut would be helpful to determine the issue too
Could you please provide screenshots of your current serial configuration on the RUT145, as well as a photo showing the physical connection? Specifically, how is the device wired, and are you using a P1 to RS485 converter?
I found out that I need a converter from the 1p port on the electricity meter. And in addition I need to convert the signal from the 1p converter to Modbus TCP/IP to get it into Schneider Power Panel PAS 600 and from there to get it into Schneider PME software.
I hope my explanation makes sense.
