Wi-FI Access-Point config
RUT_AP default creates 1 Access points.
Navigate to WebUI → Network → Wireless, click edit on 2,4Ghz Access-Point interface and set SSID, Password and other settings.Enable WDS.
Wi-Fi Client/STA config
Navigate to WebUI → Network → Interfaces and edit LAN interface.
But when it comes to the WDS bridge, the requirement is that both devices need to support it. that means there should be two RUT140 that would have a WDS bridge. This works with other vendor equipment, like Fortigate too.
Andrii.
