RUT X11 can not send sms. [gsmctl_send_sms:22] error: ERROR: Request timed out
I can not send SMS i think since a firmware update a while ago. I do not use the function regularly (UPS monitoring via curl/API) so i can not say when it stopped working.
Tried both via API and SMS utilities in the web-GUI
If i try via gsmctl i get timeout after about a minute or so.
root@RUTX11:~# gsmctl -S -s “0712345678 test”
logread is silent during this time.
The device has been factory reset.
Any ideas how to troubleshoot? Logs that is specific to the GSM-modem?
Version information:
root@RUTX11:~# gsmctl -y
EG06ELAR04A20M4G
Teltonika RUTX series 2024
Device: RUTX11
Kernel: 5.10.199
Firmware: RUTX_R_00.07.06.1
Build: 0f141b8753
Build date: 2024-01-02 09:57:45
Welcome to Teltonika Networks Crowd Support!
To resolve your issue, I need you to check on two things:
First, make sure that the SIM you’re using has SMS capabilities.
Second, access the WebUI, go to Network → Mobile → General → Turn off VoLTE. This depends on what your provider allows. In my case I had to turn OFF
Let me know if this cleared your doubts.
