I have a RUTx11 running OpenVPN and would like to view the VPN status remotely. It can be viewed via the admin page under Status > Overview but can the VPN status be viewed over MQTT or similar. I currently run Node-Red on a RPi and view GPS over UDP and Mobile signal strength over modbus and would like to view VPN status in Node-Red too.
One option is to enable the custom registers block on the RUTX11 and use a script to store the VPN status and any other required information in that block. This would allow you to retrieve the data via Modbus. You can find an example of how to use the custom register block and insert data into it here: https://wiki.teltonika-networks.com/view/Modbus_custom_register_block_RutOS
