I have a teltonika RUT TX50 and a BAT120
Is it possible to have the RUT TX50 to alert med in any way if the BAT120 loses AC power?
I need to extend the wifi range of the RUT TX50 do you have any product that will extend the wifi network provided by RUT TX50? Perhaps the TAP 200 If i connect the TAP 200 by ethernet cable from the RUT TX50 .
Important that im looking for to have one (same) wifi network provided by RUT TX50 and the added acces point.
Yes, it is possible to receive email or SMS alerts if the BAT120 loses AC power. Please refer to this article here, where you can find a detailed configuration guide for this scenario.
To extend the Wi-Fi network provided by your RUTX50:
Using TAP Series Access Points: Any of the TAP series access points, including TAP200, would be suitable. A step-by-step guide can be found here.
Using Other Routers: Alternatively, you can use other Teltonika routers to extend the wireless network. Configuration example for this setup are available here.
Please feel free to reach out if you need further assistance during setup.
