RUT 955 identify Legacy Hardware
Hello, we are using a number of RUT955 devices and all still running by OS_6.x (Legacy).
In case that we now use only RUT956 with the OS_7.x system, we want to bring up all old devices to the same condition for maintainence reasons.
Is there a CLI command or option to check wether the RUT955 device is able to run the OS_7.x.
The device are placed at different far locations and we have to check before doing a migration.
Thanks for help
Maybe I found by myself:
mnf_info -n
will print the device name but this is the Product-Code.
which will allow to identify if RUT955 is a legacy device like said in firmwares:
FW version RUT9_R_00.07.00 and above will not be supported on legacy-design (RUT955 7V**) devices.
