RUT951 with latest RUT9M_R_00.07.04.4
I configured the hotspot, the access to the external wifi (as client) and the failover.
But the hotspot users don’t have access the Internet.
I don’t have a SIM card at the moment, does this router not work without a SIM card??
What could be wrong ?
so basic functionality not working.
I can’t believe it !!
Could you please check if you did the following:
- Set up your RUT951 in ‘client mode’ and connect it to the access point. This can be done in Network → Wireless by pressing ‘SCAN’ button.
- Create a new 2.4Ghz WiFi instance. You can do this in Network → Wireless. This process will create a new wireless interface.
- After creating the new interface, go to Services → Hotspot. Here, assign the newly created interface to your Hotspot.
If you are still experiencing issues, could you please provide additional details?
- Are you attempting to connect your RUT951 to a standard WiFi Access Point or a Hotspot?
- Does your RUT951 has internet access when it’s connected to the WiFi access point in client mode, or is the problem only occurring when devices are connected to the RUT951’s Hotspot?
- Can you show your hotspot and wireless configurations?
step 1, done
step 2, done
Ocean Love is my Wifi, and D-Marin Guest is the Marina wifi
step 3, can’t find anything with : Services → Hotspot
where Do I have to add it?
The Marina wifi is a standard access point, of course it’s working If I connect my laptop or mobile directly.
The RUT951 is connected because I see Rx and Tx
Regards
A ping 8.8.8.8 from the router gui is not working, even the router looks like connected to the Marina wifi.
Perhaps the Guest network that you are connecting to requires authentication on the Captive portal?
no nothing like that.
cant upload the system.log as a new user, lol
Tue Jul 11 08:06:53 2023 user.notice /bin/trigger_vuci_routes_reload: vuci reload_routes triggered
Tue Jul 11 08:06:57 2023 daemon.notice procd: /etc/rc.d/S12simcard: Command failed: Not found
Tue Jul 11 08:06:58 2023 daemon.notice netifd: Interface ‘loopback’ is enabled
Tue Jul 11 08:06:58 2023 daemon.notice netifd: Interface ‘loopback’ is setting up now
Tue Jul 11 08:06:58 2023 daemon.notice netifd: Interface ‘loopback’ is now up
Tue Jul 11 08:06:58 2023 daemon.notice netifd: Network device ‘lo’ link is up
Tue Jul 11 08:06:58 2023 daemon.notice netifd: Interface ‘loopback’ has link connectivity
Tue Jul 11 08:07:02 2023 user.warn mwan3-hotplug[2206]: hotplug called on loopback before mwan3 has been set up
Tue Jul 11 08:07:02 2023 daemon.err mobifd: [gsm.modem0] Failed to set CFUN “minimal”
Tue Jul 11 08:07:09 2023 authpriv.warn dropbear[2675]: Failed loading /etc/dropbear/dropbear_rsa_host_key
Tue Jul 11 08:07:09 2023 authpriv.info dropbear[2675]: Not backgrounding
Tue Jul 11 08:07:09 2023 daemon.notice hostapd: Configuration file: /var/run/hostapd-phy0.conf (phy wlan0-1) → new PHY
Tue Jul 11 08:07:09 2023 daemon.notice hostapd: wlan0-1: interface state UNINITIALIZED->COUNTRY_UPDATE
Tue Jul 11 08:07:09 2023 daemon.notice hostapd: ACS: Automatic channel selection started, this may take a bit
Tue Jul 11 08:07:09 2023 daemon.notice hostapd: wlan0-1: interface state COUNTRY_UPDATE->ACS
Tue Jul 11 08:07:09 2023 daemon.notice hostapd: wlan0-1: ACS-STARTED
Tue Jul 11 08:07:10 2023 daemon.notice procd: /etc/rc.d/S16done: sh: out of range
Tue Jul 11 08:07:10 2023 daemon.notice procd: /etc/rc.d/S16done: USB system start up: OK
Tue Jul 11 08:07:12 2023 daemon.notice wpa_supplicant[1926]: wlan0: CTRL-EVENT-SCAN-FAILED ret=-16 retry=1
Tue Jul 11 08:07:12 2023 daemon.notice netifd: Wireless device ‘radio0’ is now up
Tue Jul 11 08:07:12 2023 daemon.notice netifd: Interface ‘lan’ is enabled
Tue Jul 11 08:07:12 2023 daemon.notice netifd: Interface ‘lan’ is setting up now
Tue Jul 11 08:07:12 2023 daemon.notice netifd: Interface ‘lan’ is now up
Tue Jul 11 08:07:12 2023 daemon.notice netifd: Interface ‘MyGouvia’ is enabled
Tue Jul 11 08:07:13 2023 daemon.notice wpa_supplicant[1926]: wlan0: CTRL-EVENT-SCAN-FAILED ret=-16 retry=1
Tue Jul 11 08:07:14 2023 daemon.notice wpa_supplicant[1926]: wlan0: CTRL-EVENT-SCAN-FAILED ret=-16 retry=1
Tue Jul 11 08:07:15 2023 daemon.notice wpa_supplicant[1926]: wlan0: CTRL-EVENT-SCAN-FAILED ret=-16 retry=1
Tue Jul 11 08:07:16 2023 daemon.notice hostapd: wlan0-1: ACS-COMPLETED freq=2427 channel=4
Tue Jul 11 08:07:17 2023 daemon.notice hostapd: wlan0-1: interface state ACS->ENABLED
Tue Jul 11 08:07:17 2023 daemon.notice hostapd: wlan0-1: AP-ENABLED
Tue Jul 11 08:07:17 2023 daemon.notice hostapd: handle_probe_req: send failed
Tue Jul 11 08:07:19 2023 user.notice mwan3-hotplug[2941]: mwan3 hotplug on lan not called because interface disabled
Tue Jul 11 08:07:19 2023 daemon.notice netifd: Network device ‘wlan0-1’ link is up
Tue Jul 11 08:07:19 2023 daemon.notice netifd: Interface ‘lan’ has link connectivity
Tue Jul 11 08:07:19 2023 kern.info kernel: [ 64.072229] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0-1: link becomes ready
Tue Jul 11 08:07:19 2023 daemon.notice wpa_supplicant[1926]: wlan0: SME: Trying to authenticate with bc:a9:93:32:a9:20 (SSID=‘D-Marin Guest’ freq=2462 MHz)
Tue Jul 11 08:07:19 2023 kern.info kernel: [ 64.143401] wlan0: authenticate with bc:a9:93:32:a9:20
Tue Jul 11 08:07:19 2023 daemon.notice wpa_supplicant[1926]: wlan0: SME: Authentication request to the driver failed
Tue Jul 11 08:07:20 2023 kern.notice Port link state of port CPU/WiFi changed to UP
Tue Jul 11 08:07:20 2023 daemon.notice netifd: Network device ‘wlan0-1’ link is down
Tue Jul 11 08:07:20 2023 daemon.notice netifd: Interface ‘lan’ has link connectivity loss
Tue Jul 11 08:07:20 2023 kern.notice Port speed for port CPU/WiFi changed to 1000 baseT
Tue Jul 11 08:07:20 2023 daemon.notice netifd: Network device ‘wlan0-1’ link is up
Tue Jul 11 08:07:20 2023 daemon.notice wpa_supplicant[1926]: wlan0: SME: Trying to authenticate with bc:a9:93:32:a9:20 (SSID=‘D-Marin Guest’ freq=2462 MHz)
Tue Jul 11 08:07:20 2023 kern.info kernel: [ 65.490201] wlan0: authenticate with bc:a9:93:32:a9:20
Tue Jul 11 08:07:20 2023 kern.info kernel: [ 65.530075] wlan0: send auth to bc:a9:93:32:a9:20 (try 1/3)
Tue Jul 11 08:07:20 2023 kern.info kernel: [ 65.547087] wlan0: send auth to bc:a9:93:32:a9:20 (try 2/3)
Tue Jul 11 08:07:20 2023 kern.info kernel: [ 65.673705] wlan0: send auth to bc:a9:93:32:a9:20 (try 3/3)
Tue Jul 11 08:07:20 2023 kern.info kernel: [ 65.709300] wlan0: authenticated
Tue Jul 11 08:07:20 2023 daemon.notice wpa_supplicant[1926]: wlan0: Trying to associate with bc:a9:93:32:a9:20 (SSID=‘D-Marin Guest’ freq=2462 MHz)
Tue Jul 11 08:07:21 2023 daemon.notice netifd: Network device ‘wlan0-1’ link is down
Tue Jul 11 08:07:21 2023 daemon.notice netifd: Interface ‘lan’ has link connectivity loss
Tue Jul 11 08:07:21 2023 user.info kernel: [ 66.480825] kmodloader: loading kernel modules from /etc/modules-late.d/*
Tue Jul 11 08:07:21 2023 user.info kernel: [ 66.522519] kmodloader: done loading kernel modules from /etc/modules-late.d/*
Tue Jul 11 08:07:21 2023 daemon.notice netifd: Network device ‘wlan0-1’ link is up
Tue Jul 11 08:07:21 2023 kern.info kernel: [ 66.697956] wlan0: associate with bc:a9:93:32:a9:20 (try 1/3)
Tue Jul 11 08:07:21 2023 kern.info kernel: [ 66.822437] wlan0: RX AssocResp from bc:a9:93:32:a9:20 (capab=0x1431 status=0 aid=1)
Tue Jul 11 08:07:21 2023 kern.info kernel: [ 66.830627] wlan0: associated
Tue Jul 11 08:07:21 2023 daemon.notice netifd: Network device ‘wlan0’ link is up
Tue Jul 11 08:07:21 2023 daemon.notice netifd: Interface ‘MyGouvia’ has link connectivity
Tue Jul 11 08:07:21 2023 daemon.notice netifd: Interface ‘MyGouvia’ is setting up now
Tue Jul 11 08:07:22 2023 daemon.notice netifd: Network device ‘wlan0-1’ link is down
Tue Jul 11 08:07:22 2023 daemon.notice netifd: Interface ‘lan’ has link connectivity loss
Tue Jul 11 08:07:22 2023 kern.debug kernel: [ 67.656171] wlan0: Limiting TX power to 30 (30 - 0) dBm as advertised by bc:a9:93:32:a9:20
Tue Jul 11 08:07:22 2023 daemon.notice netifd: MyGouvia (3623): udhcpc: started, v1.34.1
Tue Jul 11 08:07:23 2023 daemon.notice netifd: Network device ‘wlan0-1’ link is up
Tue Jul 11 08:07:23 2023 daemon.notice netifd: Interface ‘lan’ has link connectivity
Tue Jul 11 08:07:23 2023 daemon.notice wpa_supplicant[1926]: wlan0: Associated with bc:a9:93:32:a9:20
Tue Jul 11 08:07:23 2023 daemon.notice wpa_supplicant[1926]: wlan0: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
Tue Jul 11 08:07:23 2023 daemon.notice wpa_supplicant[1926]: wlan0: WPA: Key negotiation completed with bc:a9:93:32:a9:20 [PTK=CCMP GTK=CCMP]
Tue Jul 11 08:07:23 2023 daemon.notice wpa_supplicant[1926]: wlan0: CTRL-EVENT-CONNECTED - Connection to bc:a9:93:32:a9:20 completed [id=0 id_str=]
Tue Jul 11 08:07:23 2023 kern.info kernel: [ 67.955216] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
Tue Jul 11 08:07:23 2023 daemon.notice netifd: MyGouvia (3623): udhcpc: broadcasting discover
Tue Jul 11 08:07:23 2023 daemon.info dnsmasq[1871]: exiting on receipt of SIGTERM
Tue Jul 11 08:07:23 2023 daemon.info dnsmasq[3664]: Connected to system UBus
Tue Jul 11 08:07:23 2023 daemon.info dnsmasq[3664]: started, version 2.85 cachesize 150
Tue Jul 11 08:07:23 2023 daemon.info dnsmasq[3664]: compile time options: IPv6 GNU-getopt no-DBus UBus no-i18n no-IDN DHCP no-DHCPv6 no-Lua TFTP no-conntrack no-ipset no-auth no-cryptohash no-DNSSEC no-ID loop-detect inotify dumpfile
Tue Jul 11 08:07:23 2023 daemon.info dnsmasq[3664]: UBus support enabled: connected to system bus
Tue Jul 11 08:07:23 2023 daemon.info dnsmasq-dhcp[3664]: DHCP, IP range 192.168.1.100 – 192.168.1.249, lease time 12h
Tue Jul 11 08:07:23 2023 daemon.info dnsmasq[3664]: using only locally-known addresses for domain test
Tue Jul 11 08:07:23 2023 daemon.info dnsmasq[3664]: using only locally-known addresses for domain onion
Tue Jul 11 08:07:23 2023 daemon.info dnsmasq[3664]: using only locally-known addresses for domain localhost
Tue Jul 11 08:07:23 2023 daemon.info dnsmasq[3664]: using only locally-known addresses for domain invalid
Tue Jul 11 08:07:23 2023 daemon.info dnsmasq[3664]: using only locally-known addresses for domain bind
Tue Jul 11 08:07:23 2023 user.notice firewall: Reloading firewall due to ifup of lan (wlan0-1)
Tue Jul 11 08:07:23 2023 daemon.info dnsmasq[3664]: using only locally-known addresses for domain lan
Tue Jul 11 08:07:23 2023 daemon.warn dnsmasq[3664]: no servers found in /tmp/resolv.conf.d/resolv.conf.auto, will retry
Tue Jul 11 08:07:23 2023 daemon.info dnsmasq[3664]: read /etc/hosts - 4 addresses
Tue Jul 11 08:07:23 2023 daemon.info dnsmasq[3664]: read /tmp/hosts/dhcp.cfg01411c - 2 addresses
Tue Jul 11 08:07:23 2023 daemon.info dnsmasq-dhcp[3664]: read /etc/ethers - 0 addresses
Tue Jul 11 08:07:24 2023 daemon.info dnsmasq[3664]: read /etc/hosts - 4 addresses
Tue Jul 11 08:07:24 2023 daemon.info dnsmasq[3664]: read /tmp/hosts/dhcp.cfg01411c - 2 addresses
Tue Jul 11 08:07:24 2023 daemon.info dnsmasq-dhcp[3664]: read /etc/ethers - 0 addresses
Tue Jul 11 08:07:26 2023 kern.info kernel: [ 70.960784] wlan0: deauthenticated from bc:a9:93:32:a9:20 (Reason: 0=)
Tue Jul 11 08:07:26 2023 daemon.notice netifd: Network device ‘wlan0’ link is down
Tue Jul 11 08:07:26 2023 daemon.notice netifd: Interface ‘MyGouvia’ has link connectivity loss
Tue Jul 11 08:07:26 2023 daemon.notice wpa_supplicant[1926]: wlan0: CTRL-EVENT-DISCONNECTED bssid=bc:a9:93:32:a9:20 reason=0
Tue Jul 11 08:07:26 2023 daemon.notice netifd: MyGouvia (3623): udhcpc: broadcasting discover
Tue Jul 11 08:07:26 2023 daemon.notice netifd: MyGouvia (3623): udhcpc: received SIGTERM
Tue Jul 11 08:07:26 2023 daemon.notice netifd: Interface ‘MyGouvia’ is now down
Tue Jul 11 08:07:26 2023 daemon.notice netifd: Interface ‘MyGouvia’ is disabled
Tue Jul 11 08:07:26 2023 daemon.notice netifd: Interface ‘MyGouvia’ is enabled
Tue Jul 11 08:07:27 2023 daemon.notice wpa_supplicant[1926]: wlan0: SME: Trying to authenticate with bc:a9:93:32:a9:20 (SSID=‘D-Marin Guest’ freq=2462 MHz)
Tue Jul 11 08:07:27 2023 kern.info kernel: [ 72.077217] wlan0: authenticate with bc:a9:93:32:a9:20
Tue Jul 11 08:07:27 2023 kern.info kernel: [ 72.082990] wlan0: send auth to bc:a9:93:32:a9:20 (try 1/3)
Tue Jul 11 08:07:27 2023 kern.info kernel: [ 72.156032] wlan0: authenticated
Tue Jul 11 08:07:27 2023 daemon.notice wpa_supplicant[1926]: wlan0: Trying to associate with bc:a9:93:32:a9:20 (SSID=‘D-Marin Guest’ freq=2462 MHz)
Tue Jul 11 08:07:28 2023 daemon.notice netifd: Network device ‘wlan0-1’ link is down
Tue Jul 11 08:07:28 2023 daemon.notice netifd: Interface ‘lan’ has link connectivity loss
Tue Jul 11 08:07:28 2023 daemon.notice netifd: Network device ‘wlan0-1’ link is up
Tue Jul 11 08:07:28 2023 kern.info kernel: [ 73.045855] wlan0: associate with bc:a9:93:32:a9:20 (try 1/3)
Tue Jul 11 08:07:28 2023 kern.info kernel: [ 73.080783] wlan0: RX AssocResp from bc:a9:93:32:a9:20 (capab=0x1431 status=0 aid=1)
Tue Jul 11 08:07:28 2023 kern.info kernel: [ 73.089221] wlan0: associated
Tue Jul 11 08:07:28 2023 daemon.notice netifd: Network device ‘wlan0’ link is up
Tue Jul 11 08:07:28 2023 daemon.notice netifd: Interface ‘MyGouvia’ has link connectivity
Tue Jul 11 08:07:28 2023 daemon.notice netifd: Interface ‘MyGouvia’ is setting up now
Tue Jul 11 08:07:28 2023 kern.debug kernel: [ 73.791064] wlan0: Limiting TX power to 30 (30 - 0) dBm as advertised by bc:a9:93:32:a9:20
Tue Jul 11 08:07:29 2023 daemon.notice netifd: MyGouvia (3951): udhcpc: started, v1.34.1
Tue Jul 11 08:07:29 2023 daemon.notice wpa_supplicant[1926]: wlan0: Associated with bc:a9:93:32:a9:20
Tue Jul 11 08:07:29 2023 daemon.notice wpa_supplicant[1926]: wlan0: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
Tue Jul 11 08:07:29 2023 daemon.notice wpa_supplicant[1926]: wlan0: WPA: Key negotiation completed with bc:a9:93:32:a9:20 [PTK=CCMP GTK=CCMP]
Tue Jul 11 08:07:29 2023 daemon.notice wpa_supplicant[1926]: wlan0: CTRL-EVENT-CONNECTED - Connection to bc:a9:93:32:a9:20 completed [id=0 id_str=]
Tue Jul 11 08:07:29 2023 daemon.notice netifd: MyGouvia (3951): udhcpc: broadcasting discover
Tue Jul 11 08:07:30 2023 daemon.info dnsmasq[3664]: read /etc/hosts - 4 addresses
Tue Jul 11 08:07:30 2023 daemon.info dnsmasq[3664]: read /tmp/hosts/dhcp.cfg01411c - 2 addresses
Tue Jul 11 08:07:30 2023 daemon.info dnsmasq-dhcp[3664]: read /etc/ethers - 0 addresses
Tue Jul 11 08:07:31 2023 daemon.info hostapd: wlan0-1: STA 40:1a:58:01:a4:aa IEEE 802.11: authenticated
Tue Jul 11 08:07:31 2023 user.notice mwan3-hotplug[3890]: Execute ifdown event on interface MyGouvia (unknown)
Tue Jul 11 08:07:31 2023 daemon.info hostapd: wlan0-1: STA 40:1a:58:01:a4:aa IEEE 802.11: associated (aid 1)
Perhaps you could try enabling the option Disable Inactivity Polling and disabling the option Disassociate On Low Acknowledgement in the advanced WiFi client interface options and check if that helps?
Additionally, could you try editing the D-Marin Guest interface in Network → Interfaces → General and in the advanced options add 1.1.1.1 and 8.8.8.8 as the custom DNS servers?
I changed both and added DNS servers.
makes no difference,
the router is connected to the Marina wifi and the router can’t ping 8.8.8.8
PING 8.8.8.8 (8.8.8.8): 56 data bytes
— 8.8.8.8 ping statistics —
5 packets transmitted, 0 packets received, 100% packet loss
