RUT 951 Connecting WAN to an access point
Hi All
I am new to RUT routers. I am sure this must have been answered but I can’t find the right thread. Can anyone help?
I have a RUT 951 for my motorhome. My goal is to use a wifi access point when one is provided by a camp site and cellular data when there is no access point available.
Accordingly, my network topology looks like this:
the WAN interface ‘WifiOffload’ has a gateway metric of 1:
and is currently connected to ssid ‘BTHUB…’ acting as a client (connected to my home wifi as a test).
[The above picture shows a signal of 0% but this has been resolved by firmware R_00.07_09]
When I am connected a device on the LAN (via wifi to RUT951_1314) then all of my WAN traffic goes through WAN interface mob1s2a1. If doesn’t go through ‘WifiOffload’
Even if I configure ‘WifiOffload’ to use a wired connection (to my home broadband router) I see the same.
What do I need to do to configure a wireless client / WAN interface to serve the LAN?
Many thanks
Neil
In desperation I have just done a factory reset to remove the possibility of me doing something wrong.
I’ve put connect a working ethernet cable in physical ‘WAN’ port.
Still, I can’t see anything through that WAN interface. If I turn off the cellular interfaces it get no WAN access…
I can ping 8.8.8.8 but I can’t open a browser to any webpage.
As an ‘out of the box’ configuration I thought (from other posts) this would work?
Neil
change you “lan” IP to i.e.: 192.168.22.1
Now you have overlap with your “lan” and “wan”. Both are in the same subnet 192.168.1.0/24
Thank you Simonas… very much appreciated. It was driving me mad. It’s now working.
As you can probably guess. I don’t have to configure many networks. Once you pointed that out it made sense.
Cheers
Neil
Hi @nestall ,
Apologies for the delayed response. It looks like @Simonas has already assisted you with this, and I’m glad to hear everything is working well now! If you run into any further issues, don’t hesitate to reach out.
Lukas
