RUT 300 with RMS in network behind firewall
I’ll be installing RUT300 in a client’s network that’s behind firewall.
I want to access my router from RMS Web UI link option.
I found this page in WiKihttps://wiki.teltonika-networks.com/view/What_IP_addresses_and_ports_are_used_by_RMS%3F
Should I ask the client to unblock IPs from “Reaching RMS platform”, “RMS Management” and “RMS Connect” sections? Or just the “Reaching RMS platform”?
You should unblock IPs and ports for the services you’ll be using. If you’re certain you won’t be using RMS Connect or RMS VPNs, for example, you might leave them blocked. But to have full access to RMS as a service, all indicated IPs should be unblocked.
Thank you for explanation!
