Hello! I can’t find how to enable Wi-Fi 5 GHz in RUT 241e.
Good afternoon,
The RUT241e router supports Wi-Fi standard IEEE 802.11b/g/n which operates exclusively on the 2.4 GHz frequency band. It does not support 5 GHz (IEEE 802.11a/ac/ax).
For example for a device like RUTX50, which supports both, if you go to WEBUI Wireless → SSIDs you would be able to scan for 5 GHz as well.
Arturas
