i also get the following information from the logs:
Tue Jun 18 15:16:22 2024 daemon.info mobifd: [gsm.modem0] -CFUN- Functionality: “Full”
Tue Jun 18 15:16:22 2024 daemon.info mobifd: [gsm.modem0] -COPS- Mode: “Auto”, operator: “CLARO XXX Claro”
Tue Jun 18 15:16:22 2024 daemon.info mobifd: [gsm.modem0] -CREG- Mode: “Enabled (with location information)”, status: “Searching”, LAC: “”, cell ID: “”, technology: “Unknown”
Tue Jun 18 15:16:22 2024 daemon.info mobifd: [gsm. modem0] -CGREG- Mode: “Enabled (with location information)”, status: “Searching”, LAC: “”, cell ID: “”, technology: “Unknown”
Tue Jun 18 15:16:22 2024 daemon.info mobifd: [gsm.modem0] -CEREG- Mode: “Enabled (with location information)”, status: “Not registered”, LAC: “”, cell ID: “”, technology: “Unknown”
Tue Jun 18 15:16:22 2024 daemon.info mobifd: [gsm.modem0] IP address on PDP context “1”: “0.0.0.0”
Tue Jun 18 15:16:23 2024 daemon.info mobifd: [gsm.modem0] Network notification received “ESM failure”
Tue Jun 18 15:16:23 2024 daemon.info mobifd: [gsm.modem0] Network notification received “Missing or unknown APN”
Tue Jun 18 15:16:25 2024 daemon.info mobifd: [gsm.modem0] IP address on PDP context “1”: “0.0.0.0”
Tue Jun 18 15:16:28 2024 daemon.info mobifd: [gsm.modem0] IP address on PDP context “1”: “0.0.0.0”
Tue Jun 18 15:16:31 2024 daemon.info mobifd: [gsm.modem0] IP address on PDP context “1”: “0.0.0.0”
Tue Jun 18 15:16:34 2024 daemon.info mobifd: [gsm.modem0] Network notification received “ESM failure”
Tue Jun 18 15:16:34 2024 daemon.info mobifd: [gsm.modem0] Network notification received “Missing or unknown APN”
Tue Jun 18 15:16:34 2024 daemon.info mobifd: [gsm.modem0] IP address on PDP context “1”: “0.0.0.0”
Tue Jun 18 15:16:34 2024 daemon.err mobifd: [gsm.modem0] Modem is not attached to PS
Tue Jun 18 15:16:34 2024 daemon.info mobifd: [gsm.modem0] Connection establishment timer set to “30s”
Tue Jun 18 15:16:34 2024 daemon.info mobifd: [gsm.modem0] Attempting to establish connection to operator with “60s” of timeout
Tue Jun 18 15:16:34 2024 daemon.info mobifd: [gsm.modem0] Connected to operator “CLARO XXX Claro”
Tue Jun 18 15:16:34 2024 daemon.info mobifd: [gsm.modem0] -CFUN- Functionality: “Full”
Tue Jun 18 15:16:34 2024 daemon.info mobifd: [gsm.modem0] -COPS- Mode: “Auto”, operator: “CLARO xxx Claro”
Tue Jun 18 15:16:34 2024 daemon.info mobifd: [gsm.modem0] -CREG- Mode: “Enabled (with location information)”, status: “Searching”, LAC: “”, cell ID: “”, technology: “Unknown”
Tue Jun 18 15:16:34 2024 daemon.info mobifd: [gsm.modem0] -CGREG- Mode: “Enabled (with location information)”, status: “Searching”, LAC: “”, cell ID: “”, technology: “Unknown”
Tue Jun 18 15:16:34 2024 daemon.info mobifd: [gsm.modem0] -CEREG- Mode: “Enabled (with location information)”, status: “Searching”, LAC: “”, cell ID: “”, technology: “Unknown”
from what i understand i get the connection to the provider but cant get the ip so the process from the quectel chip just restarts.
and on other time i get the ip address on the provider but the process cant advance any more because the test from the quectel chip wont pass.
Tue Jun 18 15:26:17 2024 user.notice netifd: uqmi -d /dev/cdc-wdm0 --timeout 6000 --set-client-id wds,22 --start-network --profile 1 --ip-family ipv4
Tue Jun 18 15:26:22 2024 daemon.notice netifd: mob1s1a1 (31881): pdh4: -2027653152
Tue Jun 18 15:26:22 2024 daemon.notice netifd: mob1s1a1 (31881): -2027653152
Tue Jun 18 15:26:23 2024 daemon.notice netifd: mob1s1a1 (31881): Setting up qmimux0
Tue Jun 18 15:26:23 2024 daemon.notice netifd: mob1s1a1 (31881): Setting dynamic MTU: 1500 on qmimux0
Tue Jun 18 15:26:23 2024 daemon.notice netifd: Interface ‘mob1s1a1’ is now up
Tue Jun 18 15:26:23 2024 daemon.notice netifd: Network device ‘wwan0’ link is up
Tue Jun 18 15:26:23 2024 daemon.notice netifd: mob1s1a1 (31881): Setting up qmimux0 V4 DCHP
Tue Jun 18 15:26:23 2024 daemon.notice netifd: Interface ‘mob1s1a1_4’ is enabled
Tue Jun 18 15:26:23 2024 daemon.notice netifd: Network device ‘qmimux0’ link is up
Tue Jun 18 15:26:23 2024 daemon.notice netifd: Interface ‘mob1s1a1_4’ has link connectivity
Tue Jun 18 15:26:23 2024 daemon.notice netifd: Interface ‘mob1s1a1_4’ is setting up now
Tue Jun 18 15:26:24 2024 daemon.notice netifd: mob1s1a1_4 (32456): udhcpc: started, v1.34.1
Tue Jun 18 15:26:24 2024 daemon.notice netifd: mob1s1a1_4 (32456): udhcpc: broadcasting discover
Tue Jun 18 15:26:24 2024 daemon.notice netifd: mob1s1a1_4 (32456): udhcpc: broadcasting select for x.x.x.x, server x.x.x.x
Tue Jun 18 15:26:24 2024 daemon.notice netifd: mob1s1a1_4 (32456): udhcpc: lease of x.x.x.x obtained from x.x.x.x, lease time 7200
Tue Jun 18 15:26:24 2024 user.notice firewall: Reloading firewall due to ifup of mob1s1a1 (wwan0)
l
Tue Jun 18 15:26:25 2024 daemon.info mobifd: Auto APN is disabled for ‘mob1s1a1’. Skipping Ping To DNS functionality
Tue Jun 18 15:26:25 2024 daemon.notice netifd: Interface ‘mob1s1a1_4’ is now up
Tue Jun 18 15:26:25 2024 daemon.info mobifd: Connection setup completed for ‘mob1s1a1’
Tue Jun 18 15:26:25 2024 daemon.info mobifd: Connection setup completed for modem: ‘gsm.modem0’
Tue Jun 18 15:26:25 2024 daemon.info dnsmasq[2954]: reading /tmp/resolv.conf.d/resolv.conf.auto
Tue Jun 18 15:26:25 2024 daemon.info dnsmasq[2954]: using nameserver 216.230.147.90#53
Tue Jun 18 15:26:25 2024 daemon.info dnsmasq[2954]: using nameserver 216.230.128.3#53
Tue Jun 18 15:26:25 2024 daemon.info dnsmasq[2954]: using only locally-known addresses for test
Tue Jun 18 15:26:25 2024 daemon.info dnsmasq[2954]: using only locally-known addresses for onion
Tue Jun 18 15:26:25 2024 daemon.info dnsmasq[2954]: using only locally-known addresses for localhost
Tue Jun 18 15:26:25 2024 daemon.info dnsmasq[2954]: using only locally-known addresses for invalid
Tue Jun 18 15:26:25 2024 daemon.info dnsmasq[2954]: using only locally-known addresses for bind
Tue Jun 18 15:26:25 2024 daemon.info dnsmasq[2954]: using only locally-known addresses for lan
Tue Jun 18 15:26:25 2024 daemon.info mobifd: [gsm.modem0] Network notification received “No EPS bearer context activated”
Tue Jun 18 15:26:26 2024 daemon.info mobifd: [gsm.modem0] Network notification received “ESM failure”
Tue Jun 18 15:26:26 2024 daemon.info mobifd: [gsm.modem0] Network notification received “Missing or unknown APN”
Tue Jun 18 15:26:29 2024 daemon.info dnsmasq[2954]: read /etc/hosts - 12 names
Tue Jun 18 15:26:29 2024 daemon.info dnsmasq[2954]: read /tmp/hosts/dhcp.cfg01411c - 4 names
Tue Jun 18 15:26:29 2024 daemon.info dnsmasq-dhcp[2954]: read /etc/ethers - 0 addresses
Tue Jun 18 15:26:31 2024 user.notice firewall: Reloading firewall due to ifup of mob1s1a1_4 (qmimux0)
Tue Jun 18 15:26:34 2024 daemon.info dnsmasq[2954]: read /etc/hosts - 12 names
Tue Jun 18 15:26:34 2024 daemon.info dnsmasq[2954]: read /tmp/hosts/dhcp.cfg01411c - 4 names
Tue Jun 18 15:26:34 2024 daemon.info dnsmasq-dhcp[2954]: read /etc/ethers - 0 addresses
Tue Jun 18 15:26:36 2024 kern.info Mobile data connected (internal modem)
Tue Jun 18 15:26:36 2024 kern.info Joined LTE network (internal modem)
Tue Jun 18 15:26:36 2024 kern.info Connected to CLARO xxx Claro operator (internal modem)
Tue Jun 18 15:26:37 2024 daemon.info mobifd: [gsm.modem0] Network notification received “ESM failure”
Tue Jun 18 15:26:37 2024 daemon.info mobifd: [gsm.modem0] Network notification received “Missing or unknown APN”
Tue Jun 18 15:26:44 2024 daemon.notice netifd: mob1s1a1 (32434): Mobile connection lost!
Tue Jun 18 15:26:44 2024 daemon.notice netifd: Interface ‘mob1s1a1’ has lost the connection
Tue Jun 18 15:26:44 2024 daemon.notice netifd: Network device ‘wwan0’ link is down
Tue Jun 18 15:26:45 2024 daemon.notice netifd: mob1s1a1 (695): Stopping network mob1s1a1
Tue Jun 18 15:26:45 2024 daemon.notice netifd: mob1s1a1 (695): Stopping network on /dev/cdc-wdm0!
Tue Jun 18 15:26:45 2024 user.notice netifd: uqmi -s -d /dev/cdc-wdm0 -t 3000 --set-client-id wds,22 --stop-network 0xFFFFFFFF --autoconnect
Tue Jun 18 15:26:45 2024 daemon.notice netifd: mob1s1a1 (695): “No effect”
Tue Jun 18 15:26:46 2024 daemon.notice netifd: mob1s1a1 (695): Releasing client-id 22 on /dev/cdc-wdm0
Tue Jun 18 15:26:46 2024 user.notice netifd: uqmi -s -d /dev/cdc-wdm0 -t 3000 --set-client-id wds,22 --release-client-id wds
Tue Jun 18 15:26:47 2024 daemon.notice netifd: mob1s1a1 (695): Command failed: Not found
Tue Jun 18 15:26:47 2024 daemon.notice netifd: Network device ‘qmimux0’ link is down
Tue Jun 18 15:26:47 2024 daemon.notice netifd: Interface ‘mob1s1a1_4’ has link connectivity loss
Tue Jun 18 15:26:47 2024 daemon.info mobifd: [gsm.modem0] Network notification received “ESM failure”
Tue Jun 18 15:26:47 2024 daemon.info mobifd: [gsm.modem0] Network notification received “Missing or unknown APN”
Tue Jun 18 15:26:49 2024 daemon.notice netifd: Interface ‘mob1s1a1_4’ is disabled
Tue Jun 18 15:26:49 2024 daemon.notice netifd: mob1s1a1 (695): Command failed: Permission denied
Tue Jun 18 15:26:49 2024 daemon.notice netifd: Interface ‘mob1s1a1’ is now down
