Hello Teltonika Community,
I use the Data to Server server package to send Data via Mqtt from 11 diffrent Modbus Devices. This works fine up to the 11. Data Collection (from the Data to Server Modul). I use an Teltonika RUT 241 with firmware RUT2M_R_00.07.08.
Is there an limit how many instances of the Data Collectors i can deploy ? I also have 11 Modbus Devices.
Best regards
Chris
As you’ve discovered, the limit is 10.
Hello Marijus,
will there be some Upgrade with an new Firmware release ?
To 12 or something because this would be realy good.
best regards
Chris
We don’t have any information about future increases, but it definitely won’t be included in the next few updates. If you need to send more than the current limit, you can always create a new “Data to Server” instance.
