hi
I have a rut50 router and I would like to only be able to access one device in vlan1 from vlan2, is that possible? Otherwise everything should be closed from both vlans
Hello Jost,
Thank you for your message.
Yes, it is possible to allow access from a device in VLAN1 to a specific device in VLAN2 while keeping all other communication blocked. This can be done using VLAN Inter-zone accessibility control together with firewall zones.
For additional details, you can follow our configuration guide here:
This setup will ensure that only the specified VLAN2 device can reach the designated VLAN1 device, while all other access between VLANs stays restricted.
I hope this helps! If you have any further questions, feel free to reach out.
