Good morning,
I have a problem using the Teltonika RTU951 router compared to its predecessor RTU950, I need technical help on this device.
Usually, we use them to power our PoE network for camera management, but in this specific case, we are unable to get the 4G connection delivered to the LAN outputs. Is there a new setting?
This router was tested on a functional installation with an RTU950, but we did not have the good result with the RTU951 on the same configuration
Thank you in advance for your help
