RTU950 log in to HotSpots problem
I have an RUT950 in my boat. When I visit marinas I am given a login to the marina wifi. I can connect to the wifi from my lap top or iDevice because when I enter the password a splash screen appears and I can accept the terms and conditions. This however is no good because no other crew members can use the wifi and usually you cannot access the wifi inside the boat.
I want to connact the RTU950 to the hotspot but I cannot see how to connect the RTU950 to the hotspot because there is no access via the RTU950 to accept the terms and condition or enter my DOB etc etc.
Many yachting forums are now recommending that people remove their Teltonika cellular routers and fit another brand. Is there going to be a software update to fix this issue. It seems that other brands have now resolved this problem.
I’ve sent you a form to fill out so we can continue our conversation in private, to avoid accidentally leaking any sensitive information. In the Ticket ID field, simply enter the thread’s number, which is 14158.
