Hi Guys,
I’ve already tried a lot of things, but unfortunately I can’t get the following configuration to work:
I have a Teltonika RUTX50 Router.
The Router has an active Wireguard VPN Connection to my home (Endpoint: Unifi UDMPro).
 → The WG Tunnel works, i can connect from the Teltonika Network to the Unifi Network.
The RUTX50 has a WLAN on the Network: 192.168.1.0 (Teltonika IP: 192.168.1.1/24)
The RUTX50 Tunnel IP is: 192.168.55.2 (The Unifi Tunnelserver has 192.168.55.1/24)
I want a specific client (192.168.1.10) to send all of its traffic through the Wireguard VPN tunnel (to the internet).
All other clients in the Teltonika WLAN should access the internet “locally” via any available WAN (sim or other WLAN) as normal.
What is important here is that my normal internet access is usually set up via the SIM card. However, it should also be possible to use a different WLAN for internet traffic if necessary.
How can i archive this? i’m completely free with my config (e.g. extra WLAN Network, etc.)
Unfortunately, I’m not that technically savvy and would like to keep the configuration as simple as possible.
Is there anyone, who can help me with a (step-by-step) guidance for the Network/Routing/Firewall and DNS config?
Thank you very much for your support and best regards
Benedikt
