Routers cant connect to RMS
Mutliple Router now failing to connect to RMS since 2-3 hours
The logs seems all the same:
|The device is redirected to the authentication system.|20|2024-11-03 08:49:53|
|Closed authentication prematurely.|111|2024-11-03 08:46:19|
|Device was not authenticated yet.|116|2024-11-03 08:46:19|
|Closed authentication prematurely.|111|2024-11-03 08:43:52|
|Closed authentication prematurely.|111|2024-11-03 08:42:10|
|Closed authentication prematurely.|111|2024-11-03 08:40:46|
|Closed authentication prematurely.|111|2024-11-03 08:37:38|
|The device is redirected to the authentication system.|20|2024-11-03 08:36:27|
Devices have Access to Internet
I Tried rms_connect sms
rms_off then rms_on SMS
Still the devices refuse to connect.
We need an urgent Solution…
I see exactly the same:
+1
Same here…
Hi all,
please continue here.
Hello everyone,
Update on the current situation
Following recent maintenance, we encountered unexpected issues with connections from devices using older firmware versions, initially identified as versions prior to 07.07. The system experienced difficulty managing the abnormal connection attempts from these devices, leading to unstable connectivity across the platform.
Over the weekend, we implemented a temporary solution to stabilize the system while our team continues developing a more robust, long-term fix. This has allowed many devices to reconnect, though full operational performance has yet to be fully restored.
For critical devices, a potential temporary workaround is to retry connecting to RMS through WebUI, CLI, or SMS commands where applicable.
We sincerely appreciate your patience as we work to resolve this issue as quickly as possible. Further updates will be shared when system stability is fully achieved.
I’m seeing my first devices coming back online just now. Do you folks have any estimates to share with us?
