Hello everyone
I have two internet connections the first one is on the wan port then I created a Vlan port based called wan2 on the lan3 port
I see in the failover menu my wan2 interface but if I try to insert it into a rules where I already have the wan and the two wan-lte and I try to save the system it reports me an error (that I can’t understand which one is) I’m wrong something? I need to check some other configuration? Thanks for the help
Giorgio
Hi Giorgio183,
I have reported the issue to our development department, and I will inform you as soon as I receive a response from them. Thank you for your understanding and patience.
Kindly upgrade to the latest firmware version as fix has been added.
