Roaming-Problem with RUTOS V 07.17.1 on RUTX50
After updating to version 07.17.1, I had problems with roaming, manual network settings, and the whitelist. The router ignored these issues and kept trying to connect to prohibited providers. Ultimately, the router couldn’t establish a connection at all.
After downgrading to version 07.16.3, it’s working perfectly again.
This is for informational purposes to support.
PS: newest modem-firmware is running
To assist you further, we would need to proceed to private communication, as it will require us exchanging sensitive data.
I have sent you a form for private communication, please fill in the form, and in ticket ID provide this query ID which is 15332. This form should arrive to your personal email address used to register to this site.
Arturas
Than you - i got the PN and opend the ticket.
Now i have the same problem with V07.16.3 !?!?
This should be an answer to Ticket 15332.
The Error didn’t come up again. So the ticket can be closed.
Thank you.
Best regards
Rolf
