RMS VPN Hub Not Routing to PLC Devices
I’m following various guides on allowing a PLC to connect over an RMS VPN hub. I can ping the RUT906 over the OpenVPN client but I can’t get a response or connect establised to the internal device IPs.
If someone can help me out I’d be really appreciative as it’s time-critical.
Many thanks,
Rob
Hello Rob,
Thank you for reaching out.
Could you confirm you have added a route to your internal LAN device (PLC)?
For detailed guidance and a configuration example, please refer to this link: RMS VPN Hubs – Adding Routes.
If you need further assistance, feel free to reach out.
Hi Martynas,
Yes both devices are in the list.
Any further assistance would be appreciated, especially if you can remote in to take a look for us?
Thank you!
Have you also modified the LAN firewall zone on your RUT906 to allow forwarding to the RMS VPN hub destination and from source zones, as described here?
If the issue persists, I’d like to troubleshoot it further. For this, I’ve sent you a form to fill out, when completing it for the ticket ID use “11195”. Once submitted, we’ll contact you privately with further assistance.
Hi Martynas,
I’ve done this but still the same result. I’ve submitted the form now.
