I followed the video "how to set up an RMS VPN Hub "
at the RUTX50 I have a SDR-transiver running at 92.168.1.8 and if I put a laptop on there is no problem to runn it (power it on)
if I go in under VPN Hubs/client and download the config file and put it in
c:\Program Files\OpenVPN\config
and then try to connect to my RUTX50 I then get this on my Openvpn-GUI, and nothing happen
I cant get in contackt whit the device , not even ping it give any result ???
Here is my Log:
2024-08-17 11:20:47 Note: --cipher is not set. OpenVPN versions before 2.5 defaulted to BF-CBC as fallback when cipher negotiation failed in this case. If you need this fallback please add ‘–data-ciphers-fallback BF-CBC’ to your configuration and/or add BF-CBC to --data-ciphers.
2024-08-17 11:20:47 OpenVPN 2.6.2 [git:v2.6.2/3577442530eb7830] Windows-MSVC [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] [DCO] built on Mar 24 2023
2024-08-17 11:20:47 Windows version 10.0 (Windows 10 or greater), amd64 executable
2024-08-17 11:20:47 library versions: OpenSSL 3.0.8 7 Feb 2023, LZO 2.10
2024-08-17 11:20:47 DCO version: v0
2024-08-17 11:20:48 TCP/UDP: Preserving recently used remote address: [AF_INET]3.69.xxx.xx:37xxx
2024-08-17 11:20:48 UDPv4 link local: (not bound)
2024-08-17 11:20:48 UDPv4 link remote: [AF_INET]3.69.xxx.xx:37xxx
2024-08-17 11:21:40 SIGHUP[hard,] received, process restarting
2024-08-17 11:21:40 Note: --cipher is not set. OpenVPN versions before 2.5 defaulted to BF-CBC as fallback when cipher negotiation failed in this case. If you need this fallback please add ‘–data-ciphers-fallback BF-CBC’ to your configuration and/or add BF-CBC to --data-ciphers.
2024-08-17 11:21:40 OpenVPN 2.6.2 [git:v2.6.2/3577442530eb7830] Windows-MSVC [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] [DCO] built on Mar 24 2023
2024-08-17 11:21:40 Windows version 10.0 (Windows 10 or greater), amd64 executable
2024-08-17 11:21:40 library versions: OpenSSL 3.0.8 7 Feb 2023, LZO 2.10
2024-08-17 11:21:40 DCO version: v0
2024-08-17 11:21:41 TCP/UDP: Preserving recently used remote address: [AF_INET]3.69.xxx.xx:37xxx
2024-08-17 11:21:41 UDPv4 link local: (not bound)
2024-08-17 11:21:41 UDPv4 link remote: [AF_INET]3.69.xxx.xx:37xxx
2024-08-17 11:21:55 SIGTERM[hard,] received, process exiting
any help from the groupe ???
Eskolin
