RMS VPN end device not scanning
I have a new RUT241 that I’m using to reach an end device.
RUT241: LAN static IP 192.168.1.50 255.255.255.0
END Device: static IP 192.168.1.20 255.255.255.0 GW 192.168.1.1
When using the RMS VPN quick connect I’m able to scan the RUT241 but the end device
doesn’t populate. If I try adding it manually and establish a VPN connection, I fail to reach the end device.
If I first connect to the RUT241 web UI and ping the device through the RUT241 diagnostic, the ping is successful. Then I go to the RMS VPN quick connect and scan the RUT241, I can see the end device (192.168.1.20). Then I can establish a VPN connection and actually communicate with the end device.
The main problem is next time I boot up the RUT241, I go through the same problem of having to physical connect my PC to the LAN. So I can pin the end device through the RUT241 so it will appear when I scan the RUT241 using the RMS quick connect.
Your END Device’s GW needs to be 192.168.1.50 (the IP of RUT241) no?
