RMS VNC Timeout Guacamole error
At least once a week, I can’t connect to RMS VNC and get “Timeout” Guacamole client stoped.
The router is updated to firmware version RUT2M_R_00.07.20.5.
What could be the cause?
I look forward to hearing from you.
Hi
I have the same issue too with the access from RMS VNC.
Do you have any reply on this?
Hi
Unfortunately, the problem continues even today
I’m waiting for a response from support
Hi! We had the same “Guacamole client stoped” timeout. last Tuesday. The Issue seems to have resolved itself yesterday. We get this error occasionally. After a while it starts working again. Not sure why this is. Restarting VNC on the host PC does not seem to help.
Greetings, @telsfauto,
I hope you’re doing well.
Could you please confirm whether the issue is still persisting? Additionally, is the problem affecting only a single device, or are multiple devices experiencing the same behavior?
I look forward to your reply.
Hi, @Vilius,
I hope you’re well too.
I can confirm that the connection is currently working properly, and as @Paul44 wrote, the problem appears to have resolved itself yesterday, as it did the last two times, both on Tuesdays.
I remain available for further information, and if the problem occurs again, I’ll let you know with a new post.
Thanks in advance for your support.
Thank you for your swift response,
Since the issue for now seems to be resolved. Please updated me if it will reoccur again.
Hi @Vilius,
Just to let you know that this morning the “Guacamole client stopped” timeout error reappeared and RMS VNC not working.
The device is updated to version RUT2M_R_00.07.21.3
Thank you for reaching out.
I have forwarded the provided information to our RMS team for further investigation. I will keep you informed as soon as I receive an update on the matter.
after about two months the problem recurred today.
The device is updated to the latest stable firmware. RUT2M_R_00.07.22.3
I look forward to hearing from you and remain available for further information.
Today I also tried updating to firmware RUT2M_R_00.07.22.4 but the problem persists.
Timeout Guacamole client stoped.
