How to configure the trb140 to connect the right way to danfoss aksm800 with rms platform?
The router ip set to 192.168.10.254
The aksm800 ip set to 192.168.10.100 port 80
I configured everything like a plc connection but when i try to find my controller in route its saying no ip found.
Do i need to set static route? How to do it?
Hi tomer,
RMS Connect and RMS VPN
Under RMS connect, create an instance and select your TRB140. You can use autoscan or manually put the ip and port of aksm800. Once created, you can access your end device through RMS Connect or by generating an Access link.
Let me know if this helps.
