RMS Session Expires after 45 Minutes on RUT956
I am currently using RMS to access RUT956, and I’ve noticed that the maximum duration for an RDS session is 45 minutes. While I understand that it can time out after 45 minutes of inactivity, I often find myself actively working when this happens. Unfortunately, this leads to the loss of unsaved work, and I have to log in again.
I’ve attached screenshots for reference.
Is there a way to extend the session duration so that it doesn’t time out while I’m working?
Thank you in advance for your assistance!
To access your RUT956 for an extended period, I recommend accessing WebUI/CLI remotely in Management → Devices, next to your device.
Here you will able select for how long you want this remote access to be active:
Hi Marija,
Thank you for your detailed explanation on accessing the web UI for the RUT 956. I realize I may not have explained my question clearly.
I’m trying to access a Dell PowerEdge server running Windows Server 2022, which is connected to the RUT 956. However, the RDP session to this server is restricted to 45 minutes, and I need to extend its duration.
Could you please suggest any methods to achieve this?
Thank you!
Thank you for the clarification.
To access a device connected to your router, you can create a VPN hub, which allows for continuous remote sessions without time restrictions. Detailed instructions on setting up a VPN hub can be found on our wiki page here: RMS VPN Hubs.
Please let me know if you have any further questions or need assistance with the setup.
