when i make our RUTX Configurations, i put our Config (.uci) manuall via Putty to the RUTX. This works good and no problems in the past.
Cause of a special VPN Connection that we used on the rutx devices for our customers, we only did FW Updates local on site, cause we always import the config fresh. (So we dont click on Keep Settings on FW Update to avoid errors).
Thats why we want to put all our RUTX Devices into RMS to make FW Updates and Config Imports via remote and not local on site. All works fine, after FW Update the RUTX is reachable through RMS, but when i want to import our config via Device CLI, its not working like the local way.
When i open the Device CLI in RMS, i stops after some commands got processed. I cant make a complete import of our config with that over the Device CLI on RMS. Any ideas?
Hi, its only stopping without errors in cli, so no screenshot is needed.
I cant upload you the file that need to be imported via CLI (RMS), because its to big to post here says the forum and cause iam a new user! Cant post the complete config here with 1594 lines and cant upload through new user block from forum!
Local CLI (Putty is working fine since years with that import)
I have sent you a form to fill out. Once it is completed, I will contact you privately regarding this issue.
Please use the ticket ID 13240 for reference.
