RMS no Authentification Code for RUTX50
after the last firmware update I had lots of problems with my RUTX50. So I decided to set it back to factory settings. After installing everything new, I tried to connect to it via RMS. This did not work, because I do not have the authentication Code needed.
So I deleted the device from RMS and tried to connect it as described for a new one. But I never got this needed Authentication Code.
How do I get this code?
Thanks for help!
Found it out myself! There was a wrong number in the LAN Mac adress, which prevented the connection.
Are you still encountering any issues with connecting to RMS, or has the issue been resolved?
