RMS feature request: display actual public IP
Hi
While the RMS dashboard shows the interface IP address, it is unfortunately either a cg-nat IP or a private IP. Since I use the RMS and a VPN to my office, I don’t actually need (to pay extra for) a static public IP from my cell provider, but I do need to be able to see the what public facing IP is so that I can whitelist it in my office firewall in order to allow the vpn to connect.
I would like to be able to see the public IP displayed somewhere on the RMS dashboard, please.
For anyone like me needing a workaround to this problem:
In the RMS, open the CLI, click Connect, and log in as ‘root’, then type:
curl ip.me
This will display the IP address that the RUT WAN private IP get’s NAT’d to.
You can view the same information by clicking the Device Details icon on the Management → Devices page in RMS:
The IP address will be displayed here:
Alternatively, you can customize the Management → Devices page to view device IP by selecting the Mobile page setting.
To do this:
  1. Click on Page Settings:
  2. Select Mobile and press Apply Preset:
Now, you will be able to see the IP addresses here:
Thanks Marija. But as I said, those only show the cell interface IP address (10.85.107.13 in my screenshot) which is NAT’d by the provider behind a public IP address (174.90.x.y).
I would like to be able to quickly find the public IP address on the dashboard.
I also would like to note that having the Public facing IP address visible in RMS would be useful and not just the address configured to the WAN interface.
If we have a client that sets all of their VLANs for example to 192.168.10.1, that shows as the WAN address in RMS and not the
Thank you for the clarification. I have forwarded your suggestion to our RnD team and will let you know once I receive any feedback from them.
Hello @royh,
I hope you are doing well!
I have received feedback from our RnD team indicating that this option is not something stored on the device or retrievable by RMS. Implementing it would require changes to both RMS and the device firmware.
At the moment, as only two users have requested this feature, it is unlikely that it will be implemented.
We appreciate your understanding.
Would it be more possible to display the Dynamic DNS IP address in RMS?
You can enable the DDNS monitoring template, and then view its information in the Device details page under Other services.
That gives me exactly what I need! Thanks Marija.
Can we have an option to display the ddns IP on the dashboard if enabled?
For future reference, “IP address source” in the ddns settings needs to be set to Public to get the public facing IP instead of the interface IP.
https://ip.me is a great choice for finding your public IP address, but be kind and set the “IP renew interval” to at most once an hour. It’s free service so no need to hammer them if your setup is not mission critical.
Here’s a screenshot from the RMS DDNS config:
I would like to have this feature as well. Actually, no changes to the actual firmware is needed. The RMS already has the public facing IP address of the device: It’s the address the device has connected to the RMS from. So it is really just displaying information that the RMS already has.
This is even possible without having DDNS configured on the device (which I would like to NOT have).
