RMS connection problem RUT200
Hello team,
I’m unable to connect my RUT200 to my RMS account. The connection fails when I add a device.
Greetings, @ThomasMEG,
Thank you for your post. I have removed the screenshots you attached, as they contained sensitive information (such as the serial number and MAC address). Please keep in mind that this is a public forum, and sharing personal or device-identifying information is not recommended.
To help us investigate the issue more effectively, could you please clarify the following points:
  • Does your RMS account currently have available resources (for example, credits or management packs)?
  • Does the RUT200 have a stable and continuous internet connection?
  • Have you considered updating the device firmware? The currently installed version appears to be outdated, and several RMS-related fixes and improvements were introduced in later firmware releases.
This information will help us narrow down the possible causes and provide more accurate guidance.
I look forward to your reply.
Warm regards,
My internet connection is good.
I have credit on my account.
I updated the RUT200 to version 7.19.4.
I'm still experiencing the same problem.
Thank you for your swift response.
Please make sure that under Services → Cloud Solutions → RMS, the connection type is set to Enabled.
Additionally, could you check whether any error message is displayed in the Connection state field?
Furthermore, please confirm the device status in RMS. Specifically:
  • Is the device shown as Offline or Not activated?
  • When hovering your mouse over the status indicator, does it provide any additional information?
  • Is there a triangle warning icon next to the status indicator? If so, hovering over it may reveal an error message that would be very helpful for further investigation.
For reference, the following wiki article covers the most common reasons why a device may appear offline or not activated in RMS and outlines recommended troubleshooting steps:
Please let me know what you observe after checking these points, and we can continue troubleshooting accordingly.
Warm regards,
