RMS connection issue
We are experiencing systemwide problem and can’t remotely connect to teltonika devices. Any attempt is ended up with time out. From device prospective if you try to reconnect to rms connection will end with Failure (Server refused connection. The device may be blocked or unidentified). This problem is valid for all devices on account (30+).
Hi @milesvizor,
yes. same here. See various other posts.
Regards,Timelapse Admin
Still problem persists. Some devices can’t go online (Failure (Server refused connection. The device may be blocked or unidentified)
Please check this post RMS is down again: devices failing to connect - #21 by Aurimas
