RMS Configure Devices SET UNIQUE VALUES From File - Repost
this is a repost of an topic that was closed without any answer and since i am having the same problem I am reposting it here.
I would like to change the settings on several devices at the same time.
In the RMS you should be able to upload a csv under Configure Devices in which the devices to be configured (serial number) and the value for the respective device are stored.
Content of the example csv from the RMS:
serial,value
Serial1,value1
Serial2,value2
Serial3,value3
Serial4,value4
Serial5,value5
If I adapt my csv accordingly and import it into the RMS, the RMS does not assign it to the corresponding value, the input is done manually for each device, and the correct point to be changed is passed:
csv:
serial,value
6000944xxx,a → “Oxer 143”
6000944yyy,a → “OZONE 144”
RMS:
DEVICE… … . VALUES
OXER 143… …undefined: a → imported via csv
OZONE 144… undefined: a → imported via csv
RALLE 157… …SSID: RALLE → manually entered individually
RECKE 158… …SSID: RECKE → manually entered individually
I don’t know how to get the csv import to work.
Could you please clarify the specific values you would like to set on the devices? Are you referring to names, passwords, or something else?
Hi Marija,
i also contacted the Teltonika Helpdesk (Ticket ID #399618). Apparently the engineer was able to recreate my problem and they will implement a fix tomorrow, 18.09.2024.
I was trying to change the Wifi SSID of multiple devices at the same time. This is part of the content of the csv. i was using:
serial,value
1114094xxx,RB00_2
1114091xxx,RB01_3
1114092xxx,RB02_4_1
1114090xxx,RB02_4_2
1114091xxx,RB03_5
1114094xxx,RB04_6
1114091xxx,RB05_7_1
If you assign the SSID’s manually (without) csv import it works fine but with the csv import i doesn’t recognise the imported values as SSID’s names.
Best regards, Johannes
Thank you for letting me know that you have already received support for this issue.
If you have any additional questions or concerns, please feel free to reach out on the forum!
