Hello
I have two second level companies (A and B), I’m trying to move company B under company A. So that company B becomes a third level company.
The RMS API call /companies/move seems to describe exactly what we’re trying to do:
However, I always get a 403 Forbidden response. I have the full ‘companies’ scope on my user (from a top level company) access token. Is there anything I’m missing? I couldn’t find a way to do it in the RMS web interface either.
Many thanks
This functionality is not currently available in RMS. The best approach is to create a new company and then move the devices and users to it.
You can find the instructions for transferring resources between companies here:
Thank you, and thanks for the link.
Do you think that API call might be implemented at some point? It does seem a bit strange that it’s documented. It would be perfect for organising companies when circumstances change on the client side.
Many thanks
At this time, there are no plans to implement it. The endpoint is an old one left in the documentation.
