Subject: RMS API — POST /devices/connect returns HTTP 404
We are developing a Windows application that generates RMS Connect links for third-party LAN devices connected through a RUT241.
Authentication succeeds with a Personal Access Token containing:
devices:read
device_remote_access:read
device_remote_access:write
The API successfully:
- Finds the RUT241 using its serial number.
- Returns the HTTP Remote Access entry for the DVR at
192.168.1.64:80. - Returns Remote Access ID
4174603.
However, this request:
POST https://api.rms.teltonika-networks.com/devices/connect?access_id=4174603
with body:
"duration": 3600
returns:
HTTP 404 Not Found
Resource not found
The same Remote Access entry works correctly when opened manually through the RMS web interface.
Could you confirm:
- The current API endpoint for starting an RMS Connect session.
- Whether
access_idshould be passed in the query string or request body. - Whether another scope is required.
- Whether session creation through the API is currently supported for HTTP access to third-party LAN devices.
