RMS and Multi APN
I have a question regarding the RMS and MultiAPN feature.
Is there a way to bind the RMS on a specific APN interface?
If not, what is the logic for the RMS APN selection in case of MultiAPN?
Currently, there is no direct option to bind RMS traffic to a specific APN interface. By default, RMS traffic is routed through the primary APN interface.
As an alternative, you could try setting a static route to the RMS IPs (which can be found here) through the mobile interface as the gateway.
Hi Martynas,
Thank you for your reply.
Could you please raise this internally as a feature request?
The use case is that we have a private APN as default where we want to use an additional APN for management purposes.
Till then we will try the workaround.
