Reverse Dns rutm52
Hi
I use a Rutm52 with an esim.
I dont have an constant ip adress.
How is it possible to access the router from outside for example to know the GPS position.
In the past in this case I use a reverse DNS server, bit there are perhaps other solutions?
Thank you for answer
Marc
You can use Teltonika RMS system though it’s paid (https://instantbuyrms.com/) so the easy and free way is to setup DDNS if you have a public IP.
Thank you for answer.
I look at RMS it’s a solution but nit so cheap.
I don’t find in the documentation of rutm52 where to configure the DDNS.
Marc
For DDNS please check the wiki https://wiki.teltonika-networks.com/view/RUTM52_Dynamic_DNS
I would suggest to use noip.com since its free, guide for it in wiki:
https://wiki.teltonika-networks.com/view/Noip.com_DDNS_configuration_RUTOS
Thank you, that exactly what I was looking for!
Marc
Hello @Marc,
Could you please confirm whether your question has been resolved or if you still need any assistance with it?
Yes thank you, I receive all the information I needed, I will test when the material will be back from the boat, the first try wasn’t ok, but because of the location of the boat and eSim.
Thank you for the help
Marc
Thank you for the confirmation.
I will be awaiting your feedback once you’ve had a chance to test it.
