Restore config from old firmware
Hi community
I have created a RUT240 (FW: RUT2XX_R_00.01.14.4)
config backup following this guide:
https://openwrt.org/docs/guide-user/troubleshooting/backup_restore
Now I want to restore it on this FW (RUT2_R_00.07.06.3)
Is this possible?
Hi powerzumsel,
Restoring a configuration backup from a different firmware version can sometimes cause compatibility issues or unexpected behavior. It’s recommended to check with Teltonika Networks support or refer to their documentation for guidance specific to firmware versions RUT2XX_R_00.01.14.4 to RUT2_R_00.07.06.3. They can provide the best steps to ensure a smooth transition without any data loss or configuration errors.
I wouldn’t recommend it. The best way would be to revert to the older firmware, restore the backup, update the firmware, and hope for the best.
Hi powerzumsel;
In technical support, we do not recommend performing this backup. “backup files created on devices with newer firmware cannot be uploaded to devices using an older firmware version”
https://wiki.teltonika-networks.com/view/RUT240_Configuration_Backup
