I have a RUT955 router with these details
- Firmware version :RUT9_R_00.07.06.1
- Firmware build date: 2024-01-02 11:11:13
- Internal modem firmware version: SLM750_4.0.6_EQ101
- Kernel version: 5.4.259
. I added a new network in my firewall config file, in config zone 3 as
config zone '3' option name 'wan' option input 'REJECT' option output 'ACCEPT' option forward 'REJECT' option masq '1' option mtu_fix '1' option log '0' option conntrack '0' option network 'wan wan6 mob1s1a1 mob1s2a1 {NAME OF NEW NETWORK}
To apply the changes, I would need to restart the firewall service. I run /etc/init.d/firewall reload but I get errors as
root@RUT955:~# /etc/init.d/firewall reload
Warning: Section ‘3’ cannot resolve device of network ‘mob1s1a1’
Warning: Section ‘3’ cannot resolve device of network ‘mob1s2a1’
copying config file to /tmp/firewall_old
IPV 4
Table 0
- Clearing IPv4 filter table
Table 1 - Clearing IPv4 nat table
Table 2 - Clearing IPv4 mangle table
Table 3 - Clearing IPv4 raw table
- Populating IPv4 filter table
- Rule ‘Allow-DHCP-Renew’
- Rule ‘Allow-Ping’
- Rule ‘Allow-IGMP’
- Rule ‘Allow-IPSec-ESP’
- Rule ‘Allow-ISAKMP’
- Forward ‘wan’ → ‘lan’
- Forward ‘lan’ → ‘wan’
- Zone ‘lan’
- Zone ‘wan’
- Populating IPv4 nat table
- Zone ‘lan’
- Zone ‘wan’
- Populating IPv4 mangle table
- Zone ‘lan’
- Zone ‘wan’
- Populating IPv4 raw table
- Zone ‘lan’
- Using automatic conntrack helper attachment
- Zone ‘wan’
IPV 5
Table 0
- Zone ‘lan’
- Clearing IPv6 filter table
Table 1
Table 2 - Clearing IPv6 mangle table
Table 3 - Clearing IPv6 raw table
- Populating IPv6 filter table
- Rule ‘Allow-DHCPv6’
- Rule ‘Allow-MLD’
- Rule ‘Allow-ICMPv6-Input’
- Rule ‘Allow-ICMPv6-Forward’
- Zone ‘lan’
- Zone ‘wan’
- Populating IPv6 mangle table
- Zone ‘lan’
- Zone ‘wan’
- Populating IPv6 raw table
- Zone ‘lan’
- Zone ‘wan’
- Zone ‘lan’
- Set tcp_ecn to off
- Set tcp_syncookies to on
- Set tcp_window_scaling to on
- Running script ‘/usr/bin/attack_prevention’
iptables: Bad rule (does a matching rule exist in that chain?).
root@RUT955:~#`
There is only one SIM card in the SIM1 slot. I removed it, restarted the router and ran the same command again but got the same error.
I did try to factory reset the router without the sim card in it, then run /etc/init.d/firewall reload. Still, I got the same problem.
How can I fix this problem?
Is there a way to force closing firewall service and starting it again?
