Reset TRB500 to factory default
How do I reset the TRB500 to factory settings?
According to the documentation, the reset button should be held for 12 sec or more.
But in my case the signal strength LED is still on (even after holding the reset button for more than 30 sec.).
After releasing the button the modem immediately switches to normal state.
I need to reset the password because my saved password is not accepted by the modem and the default password is also not accepted.
All possible factory reset options for the TRB500 can be found in this wiki article: TRB500 Factory Reset.
Additionally, you may try a hard reboot by unplugging the power cable, waiting a few seconds, plugging it back in, and then waiting for the mobile connection to stabilize. Once the connection is present, try the factory reset by holding the reset button for at least 14 seconds.
