Reset to default not working RUT 901
The password for the router RUT 901 is lost.
When I try to reset to default I can reach the Web-interface after rebooting but the default PW doesn´t work.
The Firmware Update like descripted also doesn`t work.
I tried to hold the reset button longer than 12 seconds when the device was powered and also while power on restarting.
The default password dosn´t work.
I can not log in.
Hello…
Try reading this…
Could you please clarify if you have lost/no longer have your router’s default password, or, is the password printed on the back of the router not working after resetting the device?
Hi
that was the solution.
In the past admin01 was set as default.
I didn´t check the label at the backside.
Good to hear the problem is resolved now!
Please let me know if there is anything else I can help you with.
