we need to configure many teltonika rotuers with the same configuration. For this, we import a backup in the routers. But I just noticed, that the backup does also include the private SSH key and private webserver certificates.
As it is a security problem, to use the same keys across multiple devices, I look for a possibility to reset all these keys. (There is no CA involved, so the router can just regenerate them)
As an alternative, it would also help, to only create a backup from the configuration without any keys.
Edit: This question does also apply to the profiles in the backup, which contain security keys, as I just found out.
Best regards ChA
PS: RMS is not used and does not fit the use case
