Request: RUT240 .FACTORY firmware for recovery (Incorrect checksum on WebUI images)
I have a Teltonika RUT240 device that is stuck in recovery mode.
  • Current version:
root@Teltonika:~# cat /etc/version
RUT2XX_R_00.01.14.7
  • When I try to upload the latest WebUI firmware (e.g. RUT2_R_00.07.06.19_WEBUI.bin) through the recovery page, I always get:
    “Error: Incorrect checksum.”
  • Screenshots attached:
    1. Recovery page “Firmware update” screen.
    2. Error “Incorrect checksum”.
It seems this unit only accepts a .FACTORY image, not the WEBUI one.
:backhand_index_pointing_right: Could you please provide the correct RUT240 .FACTORY firmware image for recovery, or direct me to the official download link?
Thank you very much in advance.
Good afternoon,
As the firmware you currently have is Legacy, you need to follow a specific way to upgrade the firmware to newest RUTOS version.
You can find instructions in this link : https://wiki.teltonika-networks.com/view/RUT240_Firmware_Downloads\_(legacy_WebUI)
To briefly explain, you need to upgrade to the newest legacy firmware, then upgrade to a lower RUTOS version, and then upgrade to the newest RUTOS version, due software nature of the device.
Arturas
Good afternoon Arturas,
Thank you for your reply.
The issue is that my RUT240 is currently only booting into the firmware recovery page (bootloader). In this mode, the device rejects all WebUI images with “Incorrect checksum” and requires a proper FACTORY image to recover.
On the wiki link you provided I can only see WebUI firmware images, but there are no .FACTORY.bin files available for download. Without a factory image, I cannot start the upgrade path you described.
Could you please provide me with a direct download link to the correct RUT240 FACTORY firmware image (e.g. 00.01.14.7_FACTORY.bin or other compatible version), so that I can flash it via the recovery page and then continue with the upgrade steps?
Thank you in advance!
The files in the link here : RUT240 Firmware Downloads - Teltonika Networks Wiki
Are correct and you can upgrade your firmware with them. So if you follow the provided instructions, and firstly upload the newest legacy firmware, and then try to install it, thats when you get the error?
The device may have not booted correctly, please switch off the device, or reset it normally, and then try to put the device in the bootloader state again, and try to upload the firmware again, as I have just tried this method and it has worked for me.
Arturas
I have already tried uploading the newest legacy firmware (RUT2XX_R_00.01.14.7_WEBUI.bin) through the recovery page multiple times. Each time, I receive the same message: “Incorrect checksum”. I also repeated the process as you suggested (full power off, entering bootloader state again, different browser/PC), but the result is the same.
Is there a possibility that my unit requires a FACTORY image instead of the WEBUI one? If such an image exists, could you please provide me with a direct download link? This would allow me to proceed with the upgrade path you mentioned.
Thank you for your assistance.
In your case, to assist you further, we would need to proceed to private communication, as it will require us exchanging sensitive data.
I have sent you a form for private communication, please fill in the form, and in ticket ID provide this query ID which is 15296. This form should arrive to your personal email address used to register to this site.
Arturas
Hi Arturas, I have not received any email with the private communication form. Could you please resend it, or provide me with the direct link?
Hello there!
Following up on the previous conversation, I can see that the issue might still be present. The reason for the “incorrect checksum” is still unknown, even after reading your previous conversation, therefore I have to ask the following:
  1. Are you certain that the bootloader process has been done & entered properly? The entire manual of how to do it can be found here: Bootloader menu - Teltonika Networks Wiki
  2. Next, are you sure that the firmware file you’re uploading is this one:
    You’re supposed to be upload the .bin file which is available for download here: RUT240 Firmware Downloads - Teltonika Networks Wiki
  3. Finally, even if after all of these checks the problem persists, please provide me the image of your screen & the error message and we’ll investigate this issue further.
