REPOST – No replies yet, hoping for some guidance
I’m working with a Teltonika TRB140 and trying to use the Data to Server feature to forward data collected by the Modbus TCP Client to multiple MQTT topics on the same broker. (Firmware version: TRB1_R_00.07.11.3)
The problem: When I attempted to create an 11th Data to Server collection, I received an error stating the limit is 10 collections. Is this a hard limit, or is there a way around it? I need to create 20–25 collections in total.
What I’m trying to achieve: Ideally, I’d like a single connection to the MQTT broker and then route the data collected by the Modbus TCP Client to different topics as needed. However, I couldn’t find a way to do this within the interface, so my current workaround was to create separate collections — one per topic — which is what led me to hit the limit.
What I’m looking for:
  1. Is the 10-collection limit a hard limit, or can it be increased/circumvented?
  2. Is there a better practice for publishing Modbus data to multiple MQTT topics from a single broker connection?
  3. Is this use case supported on the TRB140 or Teltonika devices in general?
Any guidance or pointers to relevant documentation would be greatly appreciated. Thanks!
Original post: TRB140 Data to Server hard limitation
An engineer has been assigned to your original topic here TRB140 Data to Server hard limitation.
They will respond as soon as possible.
I kindly ask you to continue the discussion in the original topic. This topic will be closed to avoid duplicate discussions.
