Report as CSV exports without new lines
When exporting logs from RMS, the logs are all on the same line making the CSV useless.
There should be a \n after every entry, that does not seem to be added.
All headers and entries are on the same line, with no separator between entries.
Example:
Information date range (UTC): 2025-04-02 08:32:11 - 2025-05-02 08:32:11Name,MAC,Serial,Company,Sent,Received,Operator,Connection type,Maximum temperature,Minimum temperature,Device uptime,Device downtime,Connection uptime,Connection downtime,Maximum signal,Minimum signalSite1,FF:FF:FF:FF:FF:FF,6000000000,#00000 Company,93.21 MB,96.52 MB,Telenor,4G (LTE),33 °C,29 °C,30d,0 s,30d,0 s,-48 dBm,-85 dBmSite2,FF:FF:FF:FF:FF:FF,6000000000,#00000 Company,68.51 MB,56.34 MB,Telenor,4G (LTE),33 °C,28 °C,30d,0 s,30d,0 s,-48 dBm,-83 dBm
It should be structured like this:
Thank you kindly for the suggestion. I’ve generated a report on my own device via RMS, and when opening the file it came out just fine:
Perhaps it’s some settings with excel that you might have to tweak in order to be able to see them properly.
Testet again today, and now it works fine. Strange.
This topic can be closed.
