Remote SSH doesn't work
I’ve been trying (for some time…) to create an ssh tunnel between an Ubuntu Machine (M-1) and an embedded system (M-2).
The setup is the following:
  • M-2 is connected to a RUT901 router on LAN1.
  • M-1 is connected to WAN.
  • RUT901 is connected to WAN via 4G (public IP).
I have allowed remote SSH access to RUT901, and I can connect to it from M-1.
To connect remotely to M-2, I have created a port forwarding rule from WAN->LAN, and a firewall rule which allows the traffic through. However this fails - the ssh connection just stalls without any specific message.
Could you please help me out?
Could you please provide a screenshot of your configured firewall port forwarding and traffic rules?
Additionally, is it possible that M-2’s firewall is blocking WAN traffic to port 22. Could you check if you can SSH into M-2 locally from the RUT901 using the following command?
ssh <m2username>@<m2_LAN_IP>
The firewall rule:
The port forwarding rule:
M-1 can ssh into M-2 via LAN1, I tested it.
Thank you for your time :slight_smile:
Firewall traffic rule should be unnecessary. Could you try changing the port forwarding rule’s external port to a different one, e.g., 8888?
As mentioned previously, also ensure that M-2’s firewall isn’t blocking access to port 22 from WAN.
Additionally, can you check from M-1 if the following command succeeds?
nc -zv <RUT901_PUBLIC_IP> <external_port>
If this fails, the port is not open.
I removed the firewall rule.
And I changed the port forward rule to the external port 8888. Now I issued two commands:
ssh -p 22 <user_id>@<RUT901_PUBLIC_IP>
This works and I’m greeted with the RUT901 login screen.
However, when I try:
ssh -p 8888 <user_id>@<RUT901_PUBLIC_IP>
It stalls as per usual.
I tried
nc -zv <RUT901_PUBLIC_IP> 8888
But it stalls again.
I tried that command with other ports, and it failed, except for 22 - for which it succeeded.
I further tried:
sudo nmap -p 8888 -sT <RUT901_PUBLIC_IP>
Which returned:
PORT STATE SERVICE
8888/tcp filtered unknown
But when I issue:
sudo nmap -p 22 -sT <RUT901_PUBLIC_IP>
returns
PORT STATE SERVICE
22/tcp open ssh
This has to be router - port 22 is open on M-2. The router has to open port 8888 which it then forwards to port 22 of M-2.
Any further suggestions would be much appreciated.
Any further suggestions?
