Registersetting WiFi on RUT955
I have a Question regarding Registersettings on RUT955.
What is the Difference between:
Switch WiFi ON/OFF 203 204 1 | 0 Turns WiFi ON or OFF
Switch 2.4GHz WiFi ON/OFF 390 391 1 | 0 Turns 2.4GHz WiFi ON or OFF
see: RUT955 Modbus - Teltonika Networks Wiki
Thank you for your help in advance,
Roger
This message is about different wireless frequencies, specifically 2.4GHz and 5GHz. The “Switch WiFi ON/OFF” option controls both frequencies at once, turning them on or off together. However, if you choose the option to turn off a specific frequency, you can select either 2.4GHz or 5GHz.
You don’t see the 5GHz option because the RUT955 model does not support 5GHz wireless. Models like the RUTX series do include 5GHz.
