Register my rut241
its telling my on the remote webpage Teltonika RMS | Remote management system that i need to Activate the unit…HTF do I do that when none on the phone numbers work.
Where does it say you need a phone number to activate a router on RMS?
i need to call, i cant afford to wait around for a chat box
Need to call who, for what, please explain further as you are no really outlining what your actual is?
Hi…
Maybe he is want to talk with some engineer… person to person support.
Hello and welcome to Teltonika Community!
Thank you for reaching out!
Could you clarify which phone number you are referring to? A phone number is not required to add a device to RMS. It is only needed if you are setting up two-factor authentication for your account.
Here’s a step-by-step guide for adding your RUT241 to your RMS (Remote Management System) account:
  1. Log in to RMS
  1. Add a New Device
  • Once logged in, navigate to Management > Devices.
  • Click on the + ADD button.
  • This will redirect you to the “Add Device” page.
  1. Choose Device Type
  • On the “Add Device” page, select the RUT device series.
  1. Enter Device Information
  • Enter a custom device name (for example, “Office Router”).
  • Fill in the device details:
    • Serial Number
    • LAN MAC address
    • Device Password
  • You can find this information on the label at the bottom of the device or in the device WebUI under Services > Cloud Solutions > RMS.
  1. Submit the Information
  • After entering the device information, click Submit.
  • The device should now be visible in your RMS account.
  1. Ensure Device is Connected to RMS
  • If the device does not appear online in RMS after some time, verify that RMS is enabled on the device.
  • To check this, go to the device’s WebUI, navigate to Services > Cloud Solutions > RMS, and ensure that Enabled is selected under Connection Type.
  1. Authentication Code (if required)
  • In some cases, an authentication code will be provided when adding the device.
  • This code is used to authorize the device with your RMS account and is not related to the admin password of the device.
  • Insert this authentication code into the device’s RMS configuration to complete the process.
  1. RMS Credit
  • Newly added devices receive 1 free RMS credit, which allows you to monitor and configure the device via RMS for one month.
  • Additionally, new accounts receive 5GB of data, which is used for the connection option that allows you to access the WebUI of the device without the need for a public IP address.
By following these steps, your RUT241 should be successfully added to your RMS account.
For more information about adding a device to RMS please visit: RMS Devices - Teltonika Networks Wiki
There is also a Video guide: How To Add a New Device to RMS | Learn RMS | Episode 02
You can read more about RMS here: RMS - Teltonika Networks Wiki
Please let me know if you have further questions.
Kacper
Thank you , now would you happen to have a step by step for the Fallover…when the internet goes down the cell card will not take over
Hi…
Try here…
https://wiki.teltonika-networks.com/view/RUT241_Failover
