Reboot of RUTX50 via unix is not working
After typing reboot command system does not reboot
admin@RUTX50:~$ reboot
Command failed: Not found
touch: /log/reboot: Permission denied
OK
OK
reboot: (null): Operation not permitted
 Teltonika RUTX series 2025
Device: RUTX50
Kernel: 5.10.234
Firmware: RUTX_R_00.07.14.2
Build: 4bd9bb76ea1
Build date: 2025-05-07 13:01:09
admin@RUTX50:~$ which reboot
/sbin/reboot
reetings, @milunj ,
Thank you for your message,
It appears that the user account you’re currently using doesn’t have sufficient permissions to run that command. The root user has full access to all functions, while the admin user operates with limited rights — including restrictions on executing SSH commands. Please try logging in as root, and you should be able to run the command without issues.
Additionally, unless you have a specific requirement for staying on your current firmware version, I would highly recommend updating to the latest stable release to ensure better performance, security, and compatibility.
I hope this helps clarify the situation,
Warm regards,
