I need to read the Mobile IP address via Modbus TCP on a RUT955, but in the documentation, there are only register numbers for WAN IP and LAN IP.
Is there a way to read the mobile IP this way?
Best regards
pvkew
Best regards
pvkew
According to the documentation, it reads the current WAN IP address, which could be from the mobile interface or any other interface depending on the situation.
Marijus
reading the WAN IP returns 127.0.0.1, so this doesn’t work…
Could you please provide a screenshot of your Modbus reading configuration and WAN interfaces?
Marijus
Could you please provide the register number I have to read to get the mobile IP?
Hello Marijus,
internet connection works via SIM card in SIM slot 1, physical WAN-port (RJ45) is not connected.
Do you know how i can get the reading right when i read the WAN IP via Modbus TCP?
Can you please send a screenshot of your WAN interfaces?
pvkew
In the test I conducted, I used the same interface as you - mob1s1a1.
Marijus
